Lenovo Legion 5 Pro
19 Apr 2012
What sort of performance difference is there between a Pro with 5800H and 3070 compared to a 6800H/12700H 3070Ti?
I'm weighing up my options as I have CL20 dual channel RAM that should give a boost in performance on the 5800H where as the 6800H/12700H would be DDR5.
17 Jul 2005
Performance uplift will be around 10-20% depending on the game and settings used. The 6800H system won't be any faster in real terms CPU wise whilst the 12700H will be quicker in titles which hammer say a single CPU core / low amount of threads (vs the 6800H).
For context I am basing this on the following that I have tested across a number of games at both 1400p and 3440x1440:
Zephyrus G15 with 100-120w 3080 (roughly max TGP 3070 tier performance) & 6800HS
Legion 7 with 150-165w (max TGP) 3080 & 5800H
Flow Z13 with 150-165w (max TGP) 3080 & 12900H
The latter two will be faster in full GPU bound scenarios than a 3070Ti and the delta from the G15 to them is in the region of 15-25%, again depending on game and settings used.
Right now I would hold off changing over to the 3070Ti laptop from what you have as the performance jump isn't enough for the potential outlay. Annoyingly you really need a 4080 or 4090 based laptop to see any form of material uplift (for context with overclocking (~1950/15500) I can get my Legion within 10% of a 4080 based Legion at 1440p in CP2077). Downside of course is that those laptops (sans the Strix 16 with 13650HX & Gigabyte 17H with 13700H) are all £2.8k+ to buy.
19 Apr 2012
Great, Thanks for the input into it. I think you may be right in all honesty, By the time I desperately need to update my laptop we may be another generation of GPU's ahead so I may wait it out for now.
For refernece I'm currently using a 4800H/2060 laptop currently.
17 Jul 2005
Ah sorry I read your post assuming you had the 5800H/3070 machine already. :)
I would say if you can get one of those (or with a 3070Ti) for a good price then it will still be sizable upgrade from your current laptop. As you say though if your current one is doing the job then waiting for either 4xxx series price drops of 5xxx series laptops is the sensible option. :)
19 Apr 2012
I'll see what crops up but I'm in no rush to upgrade really. I'll perhaps wait for deals on later GPU's as likely won't utilise it fully for a little while yet.
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
:D
28 Sep 2003
London
I ended up buying
LENOVO Legion 5i Pro 16" Gaming Laptop - Intel® Core™ i7, RTX 3070 Ti, 1 TB SSD 16gb ram​
what is a good RAM kit to upgrade to?
1 Nov 2007
England
I'm seriously thinking of getting one around the £1,500 mark. I'll only game occasionally on it, so I don't want to go all in on a top-end GPU but would an Nvidia 4060 be OK for light gaming? Mainly the Total War series of games.
12 Dec 2006
While I still love mine with the 3060. I don't love the power brick the size of small car. As I don't game that much, I think I could have got away with a lesser gpu and a smaller more portable machine. Other than that I still think it's fantastic laptop.
18 Oct 2002
Somewhere in the middle.
I just bought myself one of these. Spec is
Lenovo Legion 5 Intel Core i7 16GB RAM 512GB SSD NVIDIA RTX 3070 Ti 15.6" WQHD Gaming Laptop
Intel Core i7-12700H 14 Core Processor | 15.6" WQHD IPS 165Hz Screen | Microsoft Windows 11 Home 64-bit | 16GB DDR5 RAM | 512GB M.2 NVMe SSD | NVIDIA GeForce RTX 3070 Ti 8GB Graphics | USB Type-C | HDMI | WiFi 6 | Bluetooth | 82RB000XUK
Price seemed good so I just hope it turns up.
Not sure about the whole pro vs non pro stuff mind.
27 Jan 2012
The king of the north!
the legions really are great! you will love it. i have been lucky enough (worked hard enough) to have owned a high end laptop from most major manufacturers and i will always chose the legions over the others i’ve used (Alienwares, Aorus, Msi & Razer) The legions just seem to be better checked out of the factory. Never any underlying issues.
18 Oct 2002
That's good to know. It was a bit of an impulse buy. But I have been looking to get a 3070ti specced one for under a grand so I jumped when I saw it.
