- 12 Feb 2014
- Somewhere Only We Know
Received my order earlier today and got finished with moving my build into the new case. I really like the look, finish and size of the case and it was a very smooth process moving and connecting all the components…very easy to work with. Only gripe is a 140mm fan doesn’t fit in the roof (with an ATX board) so I’ve moved it to the bottom for now and will order a 120mm fan as a secondary exhaust for the top.
CPU/GPU temps look to be the same as my define r6, but that’s ok as its a much nicer looking case. And the noise levels are about the same too, which is nice considering it doesn’t have the sound dampening lining as the r6.
Can you post a picture ?
Thanks for confirming about the fan size in the roof with an ATX mobo, im using Lian Li uni fans and wasnt sure if I needed 1 more 140mm or 1 more 120mm, youve basically confirmed it to 1 x 120mm.
Maybe when they release these radiator offset brackets for this case we might be able to get 140's at the top.
