Overclocking an i7 920 D0 - 4.7GHz
31 Jan 2009
Newcastle Upon Tyne
surprisingly when I turn off HT, I was able to overclock the CPU to 4.2GHz. I tried it with 1.3v but it crashed before even reaching Windows. So I put it up again to 1.4v and it booted up fine. However, the temps are still high...just on idle I was seeing it over 50C. Either more lapping is needed or I need to buy a new HSF. I currently have the Noctua SE1366 NH-U12P which has also been lapped...but I am hoping I dont need to get a new HSF so I will lap the CPU more when my Deluxe V2 comes back. In the meantime I have put the CPU back to 4.0GHz but at least now I with HT turned off I can overclock more. So all in all not bad :D
24 Jun 2004
To be honest I would be very happy with 4.0Ghz, even if there might be a little more headroom after that speed I wouldnt want to chance it, just in case it did decide to fail sooner, and I cant imagine many other people would want to go over that level on air cooling either, wven with the Noctua version.
I hope that he can get the speed running at 4.0 or maybe 4.1-4.2, then if I see a profile somewhere in the BIOS for it (not sure where the profiles would be) I would then select this and be one happy bunny, thats worth the money alone to get someone who knows what they are doing :D
31 Jan 2009
Newcastle Upon Tyne
true true :D I am happy its at 4.0GHz just the temps that bother me a little thats all...
24 Jun 2004
Im hoping that the temps are reasonable enough, but im sure that in experienced hands it will be well looked after. I wonder what level my CPU profile will be ready for me. I wonder if there will be a profile set for me for around 4.2, id be well happy if the experts think I can run at that speed at all times :D
24 Jun 2004
I would never chance going that high, no matter what I wanted. I should be able to get a speed of 4.0ghz from what I have heard, and maybe as high as 4.2ghz, but never any further than this to prolong the life of my machine, and enjoy the fast speeds that this speed boost could provide
rjk
rjk
Caporegime
OP
8 Aug 2007
its ok for short bursts
its hardly going to impact intels rated 80+ year lifespan
in 50 years - the chip in my system will probably be in a landfill somewhere
24 Jun 2004
Yeah thats true, will probably only last us all 5 years before we replace the whole thing, if that. My machine managed to stand the test of time, and is now looking forward to a long & happy retirement
24 Jun 2004
i would need to check it out
if its on air i could probably get 3.8/4ghz depending on the cooler
if you go for watercooling with a double rad maybe 4.2
i would say go for air on a noctua cooler
that way its pretty certain
but remember - we have to offer support for the system so i would send it out at the standard 3.6/3.8 overclock with a profile for 4ghz :)
I placed my order for the full system yesterday. Have you had a chance to see how far my system will overclock before you start to encounter problems? Just wish to see how good my D0 stepping chip is going when you have been overclocking it, im very anxious and excited :D
12 Oct 2005
My current settings:
CPU config: All disabled apart from HT and all cores on.
Turbo Modes: All disabled
Multi: 19
CPU Frequency: 200
QPI Freq: Full-Speed
QPI Data Rate: Auto
Uncore: 3600
Frequency: 1600
Command T1
RAM Timings: 8/8/8/21 (set to 16 but CPUZ says 21)/6/11/5/6/72
Clock Gen: Manual - PCEI 101
Voltage Config:
CPU: 1.184 (+.060)
VTT: 1.30
PLL: Auto
DRAM Volt: 1.64 (wont allow .65)
NB: Auto
SB: Auto
QPI/PCIE Pll 1.25v
Prime 95 Blend passed no errors after 40-45 mins of running, temps around 75-79. My uncore was higher at 3800 which caused BSOD within seconds of blend.
OCZ Reaper 6GB (3x2GB) DDR3 PC3-15000 (1866MHz) - can't get it higher than 800mhz at the moment.
Biostar mobo.
Anyway, 5 days of testing and endless forum reading and my first OC is starting to look stable :)
24 Jun 2004
rjkoneill - How is the overclocking of my machine coming along, have you managed to push it as far as it will go, and if so how much?
24 Jun 2004
It was built yesterday, and has been left on overnight for testing to make sure its stable before sending it out to me today for delivery tomorrow. I dont have my order number to hand right now, but my names Matthew Brougham if that helps?
rjk
rjk
Caporegime
OP
8 Aug 2007
good news - your system is being dispatched now
i have saved you profiles for 4 overclocks
you can set these by going intoi the bios and selecting which one you need
you have the following:
  • 3.6GHz
  • 3.8GHz
  • 4.0GHz
  • 4.2GHz
the 4.2 is on the very edge though - it is stable but your cooler will struggle if you dont put your case fans on high settings, i would only suggest you use this for benchmarks etc
the 3.8/4ghz is probably the ones to go for for every day use
Vantage Runs [PhysX Disabled] :
STOCK SPEED
3.6GHz
4.2GHz
Here are the overclocks...
tried to get the voltages down as much as possible
3.6 stable
3.8 stable
4ghz stable
4.2GHz
let me know if you have any questions :cool:
24 Jun 2004
After all of your tests, I dont think I will have any questions at all, and I must thankyou for all of your hard work with all the overclocking you did along with settings 4 profiles for me. I think I will either use the 3.8 or the 4.0, but will probably lean more towards the 3.8, but its nice to know the speed boost is there if I need it.
Im going to be so happy with this machine, and will find it hard to sleep tonight with the excitement of the machine arriving tomorrow, have the afternoon off work, cant wait to rush back home :D
24 Jun 2004
It does look like those 3 screens are exactly the same screenshot, but all still looks really cool. I started to feel really jealous of those screenshots until I realised its all mine tomorrow :D
