RadeonPro - How To Remove Micro stutter & Improve Frame Latency
31 Dec 2011
This explains why my switch to amd has been seemless from my 670, in fact smoother than my 670. I installed this before playing and set up profiles for my games as I was used to dynamic vsync from nvidia, I have to say it seems a much better implementation than nvidia. For some reason today it didn't start at startup and low and behold stutter in crysis, started it back up and all was well again. Lets hope these make it into actual drivers.
Caporegime
OP
12 Jul 2007
United Kingdom
Which AMD card did you get?
31 Dec 2011
A single Gigabyte WF3 7950, also had stuttering and tearing in bioshock when I tested without radeon pro last night but when I set it going again it all cleared up so it is defo much better to use radeonpro. Worth noting though that the stuttering happens when gpu usage is at 100% but when I use radeon pro and dynamic vsync gpu usage is much lower and gameplay is super smooth. Really not an issue for me as my pc is simply a games console connected to my TV so I never need more than 60hz. However would be nice if AMD did get these into the drivers.
30 Nov 2008
I might give this a go on ARMA 2 later, since I've swapped from my 480 to the 7950 I swear I am getting microstutter that I didn't have before - could be 'new graphics card placebo' and only finding problems that were always there.
Caporegime
OP
12 Jul 2007
United Kingdom
What cpu do you have? Are you using vsync? Does ARMA 2 have triple buffering?
30 Nov 2008
Using an i5 760 OC'd to 3.8 GHZ, not using vsync currently (tried with both though) unsure on triple buffering can check later on but irrc it's not something in the graphics options.
It's a strange issue though, just every 5-8 seconds there is a really slight 'pause' - only for half a second. It doesn't happen if I load up the mission editor and just run/ fly around though so I'm starting to think it could be my CPU struggling online when there is a lot to process.
Caporegime
OP
12 Jul 2007
United Kingdom
ARMA 2 is a cpu bottleneck game from memory. Most likely your 7950 isn't stretching its legs in that title.
13 Jun 2011
Anyone know/tested if this is still needed as a fix with the new driver? Specifically for bf3
These tweaks are the only thing thats made bf3 epic again!
5 Oct 2009
Hey Lt
How does one run BF3 using RP? Do I link the BF3.exe? When this is done and you launch through RP, it brings up Battlelog. Then does it work when I just join a svr?
Also SweetFX doesn't seem to work in Win8.1, but we knew that
25 Nov 2011
The KOP
Hey Lt
Sweetfx works here with 8.1
Setting up RP is very easy just add the bf3.exe to the program, enable the features you want from RP and just open bf3 had you normally would do. :D
Caporegime
OP
12 Jul 2007
United Kingdom
Pretty much what shankly said. I find the need for RadeonPro is no more for me personally. Though i still sometimes use it for the overlay, which works with BF4.
3 Oct 2009
Hey Lt
Yes, once it's set up, radeonpro will do its stuff whether you launch the game from RP, or launch it as normal through windows or origin.
Caporegime
OP
12 Jul 2007
United Kingdom
^^Thanks all
I am playing about with the settings. Using the RP in-built AA etc has allowed me to push both my cards to 99% in BF3
That's always desirable. Another thing you can try, though you might need to overclock them a bit. Create a bf3 profile in CCC. Select enhance application settings, then change the filter to supersampling. Change Morphological filtering to on. Change texture filtering quality level to very high. Click apply.
Now load up the game, disable FXAA and flick between in game AA of x2 or x4 depending what your gpu's can handle. x4 supersampling might be too demanding.
