Rasterbation! for all your decorating needs
Status
Not open for further replies.
18 Nov 2002
heres one of mine....
its all about printing them off at uni. a4 colour = 10p :D
18 Oct 2002
Overground, underground..
Aod said:
if you make it big enough, then the printer will just slice it into sections, then print them sequentially.
Might be better to do it manually in some paint type program with random overlaps to avoid having long vertical and horizontal joins. Also doing manually allows you to select the overlaps where they will be least visible on the picture.
I did this with a large group portrait using PSP. The final picture was about 2m x 0.7m and made up of about 30 sheets of A4.
26 Aug 2003
I had these two at one point:
And at another time had this one:
I'm going to bang another one out (fnar!) soonish, these walls are all naked (fnar!) so I shall erect one (fnar!) to satisfy myself (fnar!)
18 Sep 2003
London
mattbrown91 said:
Where did you get that image from? or if you had a link it would be great :)
just do a google search for evil money on google, and in advanced select only large images. You should get some good quality ones around the bottom of the page. (avoid the top results. My eyes wont be the same)
Ive just rasterbated a 4x4 one of that picture, full colour, 1mm dots.
Status
