A quick note for those that run pihole from an Ubuntu VM, the minimum Ubuntu version that pihole now supports is 20.04 - just had to upgrade a couple of 18.04 VM instances which I and a friend host.
Sorry if I didn't make it clear. I signed into my VM Hub and had the DHCP page open then the same on the Pi-Hole. Turned DHCP off on VM Hub, saved and signed out. Went to Pi-Hole, turned DHCP on and saved. Bit of a learning curve but hopefully now I've told the Pi-Hole to use from 192.168.0.10 upwards instead of from .200 upwards and giving my network devices a static DHCP lease will prevent it from happening again.Ah right, I misread. Client DHCP behaviour is a funny thing at times, depending on OS, some refuse to get a new address until you do a release/renew.
Did you manage to get this up and running fine on your pi?Has anyone with a Samsung TV blocked any domains to prevent their Samsung TV getting ads? I found this list and wondered if anyone had either used it or come up with their own one?
Samsung Smart-TV Blocklist Adlist (for PiHole)
GitHub Gist: instantly share code, notes, and snippets.gist.github.com
Not yet, haven't had time to be in front of the TV to test it.Did you manage to get this up and running fine on your pi?
Will give that a go sometime. Thanks.Just use the Perflyst/DandelionSprout Smart-TV Blocklist. It's updated and works, and includes domains for all common SmartTV shenanigans.
PiHole (domain format)
AdGuard Home etc (AdBlock Plus syntax format)
Any news if you managed to get Samsung TV blocked list up & running on pi-hole? Is it effective enough to block ads but still manage to update apps? CheersNot yet, haven't had time to be in front of the TV to test it.
No, I just used the Perflyst/DandelionSprout Smart-TV Blocklist as suggested by Rainmaker. Haven't really checked for ads but will try to tomorrow.Any news if you managed to get Samsung TV blocked list up & running on pi-hole? Is it effective enough to block ads but still manage to update apps? Cheers
Useful tip.New to SBC's. Not techy at all but just got an orange pi zero 2 to run pihole. Blocking about 1500 queries a day .
