Caporegime
- 30 Jul 2013
Someone on the avs forums managed to get a third party sub working.
I'm not on there, I don't suppose you could find a link to that?
Let us know once you've had a play or if struggling with anythingWell, mine are here...
Well done! If anything will do a good centre it is A90J. I haven't found the HT-A9 centre lacking at all, though.Pretty sure I snagged the last one from Currys just now.
Should pair nicely with my Sony A90J as the centre.
Same except voice off and advanced auto volume off.So I'm sticking with these settings below. After testing various movies, programs, all the different codecs, I'm happy with how it all sounds in my room. Find it makes the center channel the best it can possibly be but still keeps that really good sound bubble.
Remote modes:
Sound: Auto
Voice: On
Immersive AI: On
Modes changed in advanced options:
Audio DRC: Off
Sound effect: Sound mode On
Advanced auto volume: On
Do you mess around with the levels of the rears? Do you max it or keep it at 6 or 8?
I am Qobuz on Chromecast (I mainly use Qobuz) and the 360 sound mapping with Immersive AE on the music is excellent even though it's on 2 channel high Res musicI've just been using Chromecast off of my phone at the moment with Tidal. Can't get Atmos or master, but then hifi still sounds very good. 360 works and that seems to be where it's at. I'm not a massive music listener and didn't buy the system for that anyway, so it's good enough for me.
I've got the rears on 10. Personal preference again, but that's where Sonos lacked. I might try manually tune it at the weekend with a sound meter and get them all at same volume and see how that is.
I find with voice and auto off the center channel is too weak. Also find anything below volume 30 is weak as well.
