X79 Overclocking Guide
Man of Honour
13 Oct 2006
It will depend a bit on the quality of the memory controller on the cpu, number of slots populated and the RAM itself, I'm running mine at 9-10-10-21 @ 2133 with 1.065 vtt and 1.01 vccsa(imc on my board) but you could easily need upto 1.15. If your using 1.2+ and crashing still either the imc isn't upto it or the problem is elsewhere.
14 Feb 2011
Morning...
When pushing for high ish! clocks on Sandybridge E. I get the odd 101 blue screen crash. Is this always down to lack of vcore or could it be down to something else?
Man of Honour
13 Oct 2006
Morning...
Usually not enough vcore but can also be down to the delta between vcore, VTT and IMC(VCSSA) voltages. They shouldn't be too far from each other but also you can in rare cases get issues if one is too close - IIRC the usual advice is to keep both VTT and IMC fairly close together and neither more than 300mv less than the vcore. Don't exceed 1.15v on the additional voltages though unless on high end cooling and/or are prepared to replace the CPU if you kill it heh. (I know someone who reproduced premature degredation on 3820s with only 1.2 VTT :S).
Kei
Kei
24 Oct 2008
South Wales
129 x 35 on 125 strap. 1.35v Vcore, VCCIO and VTT 1.15- 1.2 XMP memory timings approx 2400 speed. Should be fine.
Ignoring the memory speed, would this still apply for a 4820K combined with 4x4GB kingston hyperX genesis 1600? Presently I've got it clocked up to 4.5GHz using 100 BLK and 1.225Vcore and temperatures so far have peaked at 58 on one core using linX. (the rest hit about 55-56)
The biggest stumbling block is the ram as i simply didn't have the budget to get anything better. It's not a matched set of 4, but 2 dual channel kits combined. (already owned a set of grey modules) The newer pair of modules have a tRFC of 208 vs the older ones being 128. The board seems to have used the xmp profile of the older modules, which i guess may hinder my attempts to overclock further.
5 Sep 2011
Surrey
What are the IMC's like on Ivy-E. I'm thinking about going for some super fast dimms but is it still hit and miss like with SBE whether or not I'll be able to hit them?
TBH I might just go with 2400 as anything over still gives crap returns doesn't it? Going to see what my 1866 modules can do at 1.7v firstly though.
5 Sep 2011
Surrey
What's more preferable 2133 or 2080 at 130blk for 4.8 ;).
Laxed offs timings but can't seem to get this stuff to post at 2400 at anything under 1.9 which is a bit crap.
I hate memory overclocking :(
Need smaller dimms
EDIT: Yep, these dimms don't want to do any more than 2333 without silly volts. Tried VTT /SA at sensible and non sensible levels. Time for smaller faster DIMMS
OcUK Staff
OP
20 Feb 2012
John Smiths Stadium
1866 Corsair?? Corsair bin well so you pay premium for Overclockable stuff. There Samsung IC stuff 2400+ is some of the best around. Beneath this is sadly beneath!! for the bencher that is.
5 Sep 2011
Surrey
I'll pick up some faster stuff later in the week. Makes it easier :D
Could you give us some timings to try out Ian with the 32GBC10 kit just to make sure it's not me?
They're big dimms but it is the plat stuff so thought it would clock a little higher.
Currently at 130x37 4.8ghz
VRAM 1.65v 2080mhz 10-12-11-30 which is already laxed
For these cpu vcore is at 1.4v VCSAA @ 1.12 everything else in auto.
Rock solid at those settings at the moment but memory clocking still fraggles my lil head
5 Sep 2011
Surrey
Ian, I went for the C9 2133 1.5v Dom plat stuff. Any chance you can gauge whats best to try now?
Memory clocking is still very much new to me.
Had a quick play last night and on 125 strap I can get 130 BCLK 2400+ @ 1.65v 10-11-12-31-CR2 - tried tighter primaries but had a few BSODS
VCCSA @ 1.15
VVT @ 1.1
CPU 4810mhz @ 1.4v
Are the secondary timings worth touching on these? or more importantly will upping VCCSA / RAM V allow for tighter timings possibly? I don't foresee being able to hit 2666 24/7
but that was never the aim. Would rather go for tighter timings.
Cheers
esr
esr
28 Mar 2014
hello OCuk.
I am Erik. New to over clocking so I came here hoping to find some answers.
I have posted around the web but no one either knows the answers i am searching for or i write to much, so i will simplify.
I have a sabertooth x79 with a 3930k and 64 gigs of gskill ripjawsz 1600.
I have completed my first over clock, though most of you will feel it was easy, i took the journey to understand the process of over clocking.
i am at 4.0ghz, 1.168vcore, .868vccsa, vtt1.05 and my pll at 1.5875.
I am stable.
for my very first question, anybody out there got a sabertooth board? and if so is there any software that will read all the voltage measurements from the saber?
i have tried hwinfo, hwmonitor, occt's monitors, the asus ai suite, nothing reports it. i usually get vcore and then my 12,5,3.3 rails.
on some monitors i get vin3(hwmonitor) and on others i get vcore, vin0 vin 1,3,4,6.
I would really like to know what these values are as they do not have names and its hard to spot who is who.
My purpose is to turn down my vccsa voltage to its lowest operating point, but I would have to set an offset blindly as I can not see the vccsa voltage. right now i have it locked at .868 manual.
I have other questions regarding the 3930k voltage deltas but those will come in a bit.
Thanks for reading and helping.
Erik
5 Sep 2011
Surrey
Here is my 24/7 settings
4960 @ 4.5
2133 C8-10-10-27-T1-88 @ 1.6v
Vcore offset 010+
VCCSA @ 1.0
VTT @ 1.0
PLL @ 1.4v
11 Mar 2012
portsmouth
hi mjfrosty i have the same ram cant seem to get it to work above 2133
oc is at 4.3 would ideally like to hit 4.5 but lack the knowledge to get it any higher,
is that 4.5 of yours the only settings you have changed.
thanks
