- 12 Jun 2006
I know its not good,but its my 1st one and ill just use it to learn.Now I have another problem,I cant fit the pump's screws with the holes in the case.I can only fit 2,and they are on the same side.I was reading a review in which the author had the same problem.No matter where I place the pump,it simply wont line up with the holes.I also measured the distance between the holes and it doesnt match
