I can summarise this whole post in three sentences for those of you with a small amount of time:
I have an Apollo Vendetta which isn't nice to ride - so I want to get a new bike. I'm looking at the Specialized Hardrock Sport Disc which can be had for aroudn £300. What's your opinion on this bike, do you have any alternative suggestions for the same money (or less), and can you find this bike any cheaper than £300?
This is the bike:
http://www.specialized.com/bc/SBCBkModel.jsp?spid=22092
For those of you who have a bit more time to spare, here's a more full featured explanation!
Currently I have an Apolla Vendetta (as pictured in dogoids sig). It's "OK", but heavy as hell, and made from some cheap stuff - e.g. my chain pinged off a while back and completely bent the front mech!
I had to use pliers to bend it back into a shape that changed gears properly. Also the wheels appear a bit buckled and I haven't done anything that bad on it.. So I'm looking for something a bit lighter and a bit better built.
Also, I'm looking for a bike without rear suspension - it will be lighter and won't suck up my pedal power when going up hills
I'm looking at a 2007 Specialized Hardrock Sport Disc. The cheapest I can find this is just under £300 all inclusive (£298.89). I presume this will at least be a better build quality than my Apollo, even if they're only basic cable discs... But I don't know much about bikes at all - I just know how to ride them!
This is really the max I'm willing to spend unless there are some big gains for the extra money.
The kind of riding I do is casual cross-country with a mate. This is a ~2 hour bike ride which we do 9/10 times we go out:
You can see the route for yourself here:
http://www.flashearth.com/?lat=50.849166&lon=-0.399495&z=15.6&r=0&src=ggl
So! Any opinions on this bike, alternative suggestions, or cheap finds on this bike, are muchos appreciated
Thanks
This is the bike:
I had to use pliers to bend it back into a shape that changed gears properly. Also the wheels appear a bit buckled and I haven't done anything that bad on it.. So I'm looking for something a bit lighter and a bit better built.Also, I'm looking for a bike without rear suspension - it will be lighter and won't suck up my pedal power when going up hills
Thanks
