Advice on Raid and partioning for new Install please
18 Oct 2005
Kendal
Hi All,
After 3 years i have finally decided for a PC upgrade my new Q6600 and Abit IP35 pro, 2gb Ballistix has arrived.
Would you guys mind helping me work out the best partition and sata setup for a dual boot of XP32 and Vista64 please.
I have 2 X 74gig Raptors and one 300gb Sata Seagate
I will be using Vista for gaming and hopefully the majority of other apps, I will be using XP for video editing as my software is not Vista compatible
My intention was to go Raid 0 for the raptor and partition it into 4
1:Vista System 40gb, XP System 10gb, 3:Games 40, 4:Movie Editing 50
Then the seagate into 5
1:My Documents 50gb, 2:Music 60gb, 3:Downloads 40gb, 4:Movies 50gb, 5:backup 100gb
Does this make sense ?
What is the best stripe size for the raid 0 ?
Anything else I should think about ?
Thanks
Shorty
Shorty:
I would make the partition for XP, 15GB, Vista 30GB, and the remainder of the RAID volume leave as it is, and just install your games in 1 folder, which really is a kind of partition in itself (ie a container to store data), and use the rest of that partition for your Movie editing installing the programs either in XP or Vista.
For a dual boot, you need to install XP 1st, then Vista.
I would not bother partitioning the Seagate, but just make individual folders for your purposes.
I suggest a RAID0 stripe size of 32KB :)
One thing I meant to question about not partitioning is this.
I am going to be capturing a lot of avi from camera which is usually over 10gig and then overtime deleting. Is it not better to have partitions to reduce fragmentation ?
The larger the file, the less prone it is to fragmentation, so I don't think there is going to be a problem with fragmentation with a 10GB file, especially with using NTFS (as I presume you are). :)
Video editing requires fast drives... so I would RAID 0 the raptors and use the seagate partitioned thusly
C:VISTABOOT = 15-20 (don't use it so not too sure)
D:XPBOOT = 10
E:GAMES = depends how many you got
F:PROJECT = 40 (For all small project files and reference footage)
G: STORAGE = Whatevers left
H: RAIDARRAY = the two raptors
mine is set up as this http://forums.overclockers.co.uk/showthread.php?t=17674305&highlight=username_FunkyCowie
The internal ports are connected to the Intel ICH9R controller, it's as good an onboard controller as you'll get.
I have never tried raid before, I fancy having a go at this if my internal controller is ok. Might try and see if I can pick up another 150GB raptor cheap enough and Raid 0 them together.
