Man of Honour
- 17 Feb 2003
- Chelmsford
Ok, I know the first thing your going to say is download and run Norton Removal Tool.. but this is driving me nuts.
I firstly removed NAV from the remove programs in control panel.
Then tried running the Removal tool which came back and said that I needed to remove the product from windows before running, which i had already done (as above).
So i then ran Cclean to clear anything that may have been lurking around.
Still didn't work.
Then ran regcleaner to remove all known entries and libraies etc.. which it managed to clear some bits. I was then able to run the Removal Tool which completed normally.
Then i go to install AVG.. which can't run as it says that NAV i still running
Any idea on this?
thanks
Still didn't work.
Any idea on this?
thanks
