Have you not tried doing a clean install yet?
Not necessarily. I had a P4 that had been given too much voltage throughout its life and had suffered electromigration... although it booted into Windows it would bluescreen randomly (even at idle). Problem was replicated across several Windows installs and several motherboards so it was 100% the CPU to blame.IF your cpu was dead it wouldn't even boot into bios. Much more likely the motherboard is fubar or your windows install.
okay thats weird.
one other thing tho, when rebooting or turning the machine on, it powers up for about 3-4 seconds with no post. then turns off for a few secs then turns back on and posts.
any idea why? this is when i reboot & start the machine up.
Ive had a C2D E6320 die on me before, i just didnt get a display on my monitor at all, tried different gfx cards, RAM, mobo. Took it to OcUK and they declared it dead so i got a replacement![]()
Why don't you reinstall Windows? A few times in the past a dodgy overclock has corrupted my windows install.
Mem volts @ 2.2V - CPU Vcore was about 1.45
Temp on load around 57 degrees. (stock cooling)
Its the B3 stepping.
