Nice move mate
....oh and you should be locked up for that cable management![]()
oh ninja Don edits for the win lol. anywaaaaay. tom, what in your opinion, is the best thing about upgrading to the gtx?
16xCSAA should work a treat on that. I use 8xCSAA in most things on my 8800GTS but I remember you having problems when it came to memory limitation when you had the 320MB model.The ability to use 8xSSAA in more than a few games without a hitch. Haven't even tried out 16xAA yet as 8xSSAA is more than enough for me. Might have an experiment later. Been very busy so have barely had a good test on it yet![]()
Needless to say, you won't have that problem anymore.
No not with supersampling, when I said I use 8x I meant I usually use it on its own. I can use 8xCSAA with supersampling in older games like BF2 but for newer games I have to cut back a bit to something like either 8xCSAA on its own or 4xMSAA with supersampling (Oblivion etc.)Yea but can you use 8xAA with Supersampling in most titles?. This is what I am using atm.
GTX installed..
(Excuse the mess)
If the GTX can do 8xCSAA and supersampling in recent titles then it might indeed be worth me getting one!
Nice one, let us know how it goes. It might fall on you to convince me into buying one.Correct I have tried a few games and it seemsed using 8xAA with Super was pretty achieveable, I will try out a few others.
Nice one, let us know how it goes. It might fall on you to convince me into buying one.![]()
If you have Oblivion on then let us know what the max settings are you can run comfortably (with vsync on.)Any particular games you would like me to test. Im not doing much tonight so I can give a few a whirl!
