- 8 Sep 2005
- Chichester
Well i was away for 4 days, and turned all my PC off at the mains as i wasn't going to be using it. I get back after being away, turn the mains on, press the power button on PC, and nothing. Check inside the case, mobo lights are on. Check all leads, everything is plugged in. I have all my stuff plugged into a 6 way extension plug, so i took just the PC plug out, and put it straight into the mains. The pc now powers up for about 0.5 seconds. PSU, cpu, case, gfx and mobo fans/lights all come on, and then turn straight off. But one of the PSU fans keeps spinning until i turn the PC off at he mains.
PSU borked? The extension plug isn't surge protected, but all the other equipment i had plugged in is fine...including my laptop. Any ideas?
