Crysis Multiplayer Beta now on Fileplanet
Ok this is looking a bit more promising Im now running @ 2xAA and the graphical bugs I experienced seem to have improved
I can only presume this is a game/driver bug
With the specs in my sig it runs fine at 1280x1024 with everything on High and no AA. This is without the new Nvidia drivers which i my try later. Very good game. Looks much better in motion compared to the screenshots.
Btw for anyone wondering, fsaa doesn't seem to work in the demo, at least not when its set inside the app itself. Mine is set to 4x and ingame its very obvious nothings getting anti aliased, and thats with the crysis driver that got "leaked".
forcing it in nv control panel just makes the game spazz out with things turning totally black.
Because those that have access to the game currently are under a strict NDA (None Disclosure Agreement) meaning if they do post any information or screenshots about it, Crytek or EA could take legal action against that person.
Exactly, although tbh, I'd be more worried about getting kicked out of the beta.
Any chance of FPS averages? We have a pretty similar setup and im curious to know how well it actually runs
You should if you dont want to be taken to court and/or sued.
It does happen, its not just there to scare you or fill up an empty space on your screen.
+1
TBH Im amazed that OCUK is allowing people to violate the NDA here, but Ive always been a kill joy :)
See some of you online tonight, be gentle with me...:p
2007-09-11 15:39:29 - Crysis
Frames: 8447 - Time: 272139ms - Avg: 31.039 - Min: 9 - Max: 65
May seem quite low, but it really doesn't feel like 31fps. And the 9fps part was when i drove a car into another one and crushed it causing a big explosion, but it was slow for only a split second.
Also take into consideration that this is running under Vista. It is not properly supported in the beta (says a certain file that comes with it). But really it plays completely fine to me anyway.
Same here. :)
The game runs extremely smooth even when the framerate drops down to 30fps etc.
