CS:S Stress Test
Then you seen this picture and smelt my beard......
And then i still call bull, noway you get that score at those settings when an ultra and faster CPU get 230fps, oh and below is my updated bench with my 2900xt, i noticed how you can change the settings whilst keeping the previous settings benchmark score on screen, say i did the bench in low settings then changed the config panel to all high.;)
http://img265.imageshack.us/img265/6726/yuytujb8.jpg
Yeah I'm sceptical when i see dodgy results, want more proof, look at his screen, you can see the the triangle next to the AA tab and reflections tab is white meaning it has been changed after the benchmark was run.;)
how your windows is set up and the drivers u use makes a lot of difference...maybe he has a tweaked config...tweaked drivers ...maybe he has tweaked windows for performance......all these things do make a lot of difference.
i got over 300 fps with a 2.4 at stock speeds and a 7800gt with no tweaking.
my fps now
not sure why my fps r reporting as high as they are but thats what its showing.
i got a 8800gts oc and e6600 (stock speed)
before swapping over to my old 7950 gx2, i tested my new 2400XT. didnt tell me max or min - just average fps. do you have to go somewhere for that info?
anyways - looked good and got 58 avg : 1920x1080
css doesn't give the max and min fps....
u could use fraps for that..
47.44fps on my system with all ingame setting at max (4xmsaa and 16xaf, all on high)
thats with x2 4400+, 2gb pc4000 ocz plat and 7300gt all at stock @14x9
Curious what most people get in this and what their setups are?
I got 237.22 with the specs in my sig (except the 7900GT was at 675/910)...is that reasonable?
Oh and this is at 1440x900 everything on maximum
By everything on max do you mean 6xAA? Nvidia doesnt do 6xAA and defaults to having no AA whatsoever so thats probably the reason for your high fps.
