- 12 Jun 2006
I just finished building my new system(specs in sig)installed cpu z and core speed is 1632mhz!This isnt normal is it?Is there something I should change from bios?
Set some time aside to read the motherboard manual, that would be a good start.tell me what to do?
Try turning off C1E in the BIOS as well as EIST.
Cool thanks,but is this recommended?I mean,if I turn them off,is it possible to damage my cpu?Do you have it disabled aswell?
Mined enabled, which I much prefer due to lower heat when in low usage mode, and also lower power consumption. Disabling Speedstep won't damage your processor, but I do recommend leaving it on unless you are overclocking.Cool thanks,but is this recommended?I mean,if I turn them off,is it possible to damage my cpu?Do you have it disabled aswell?
