- 12 Jun 2006
I just finished building my new system(specs in sig)installed cpu z and core speed is 1632mhz!This isnt normal is it?Is there something I should change from bios?
.cpu z says that the multiplier is 6,I dont know anything about overclocking but shoudnt that be x9?Can anyone with a Abit IP 35 PRO tell me what to do?Set some time aside to read the motherboard manual, that would be a good start.tell me what to do?
Try turning off C1E in the BIOS as well as EIST.
Cool thanks,but is this recommended?I mean,if I turn them off,is it possible to damage my cpu?Do you have it disabled aswell?
Mined enabled, which I much prefer due to lower heat when in low usage mode, and also lower power consumption. Disabling Speedstep won't damage your processor, but I do recommend leaving it on unless you are overclocking.Cool thanks,but is this recommended?I mean,if I turn them off,is it possible to damage my cpu?Do you have it disabled aswell?
.Off topic,in bios the CPU temp is 30C,is it ok?I am using the watercooling kit that came with my TT Armor.
