- 12 Jun 2006
I have 2x1Gb Ballistix 6400(800Mhz) and they are supposed to have 4-4-4-12 timings.Cpuz says 5-5-5-18.I searched in the bios and there is an option to change the timings manually(they are in auto mode now)but there are also some other options in the same page that I dont know what to change them to.Should I manually change the timings?And what about the other options?
.My first "tweaking"attempt and I already messed it up lol.
), so you'll not have to worry about your memory whilst overclocking the CPU (providing you set the memory divider/ratio to 1:1). Once you have finished working on the CPU you can then raise the divider/ratio if you wish.
