In contrast to what you've said I think that looks like a great layout.Asus Maximus Extreme
RAM slots not in line with the top PCI-E slot.
PCI slot above the top PCI-E slot
Whats going on? No motherboard manufacturer would even consider making a semi decent layed out motherboard.
- PCI slot above the top PCI-E slot means you could stick your soundcard in it and not have to reduce the cooling effectiveness of the graphics card(s) as you would if it was underneath.
- BIOS battery well out of the way of the cards - should be easy to remove and replace when you want to do a "clean" BIOS upgrade.
I'm loving the SATA ports aligned horizontal as opposed to "coming out of the board" too... I can't use two of my 4 ones on my P5W64-WS because they're obstructed by the graphics card & Southbridge cooling.
Shame it will be DDR3 though, the Maximus Formula is the DDR2 one and it looks totally different & has a worse layout to this.
