ICH8Rgigabyte sata2 or intel ICH8R?
EitherShocky-FM said:IDE or AHCI?
I think AHCI enables stuff like NCQ, however running it as IDE just makes it normal IDE styleee and therefore no NCQ.Ok, thanks. When I enable AHCI the gigabyte sata screen appears on boot, seems a bit pointless just for an ide optical drive as the HD's are on the intel ports.
The Gigabyte RAID screen would only appear if you have selected the Gigabyte AHCI option instead of the Intel option. The Intel RAID screen will appear if you have selected it.
There should be two SATA mode options in the Integrated Peripherals menu.n use the other one for the Intel controller.
