Crysis Multiplayer Beta now on Fileplanet
I just tried changing the GFX option in the cfg file to number four from three to see if it enabled very high setting just like it was suppose to in BF2 and i got the option for very high in the options menu. Now IMO i think it works, my performance hit the deck but the game looks even sweeter, especially the water and the textures seem even more detailed but the performance is so bad.:(
*snip*
Where is the config file? Ill try this now.
I just got the same as RavenUK with my graphics settings exactly like that. And I think I could notice a difference, though this is the first time ive played the second release of the beta.
Time to do some close comparision of high and 'very high' if it even is very high I think. :)
Its in -my documents/my games/crysis mp demo/game cfg file-you may have to open it with notepad, then scroll down to where the GFX options are starting at sys_spec_GameEffects and change all of them to 4, exit then save.
Here's some more screens, you would be forgiven if you thought the last screen on here was a real photo of mud and sand but its actualy in game:eek: forgive my fetish for lockers but the paint finish really catches my eye.
afaik, even if you enable the options in the cfg file, it wont make a difference, it doesn't have the full rendering system to do it, hence why it's not avaliable in the menus my default.
Works or works not, it says very high in the options so ill take it at that, either way it still looks stunning and for all the doubters out there, here's some screens, now with complimentary bullet holes and check out them leaves, omfg, best game ever, yeah I'm shallow:XD
