Nvdia 163.69 Drivers now whql
These drivers are fairly awful. Nvidia introduced a new bug in 163.44 with UK PAL CRTs and has been in every driver since. The picture is Monochrome. Its trying to use NTSC as output.
Am experiencing the same problem, TV-out is black and white regardless of output signal setting, had to reinstall older drivers. :(
Did you both manually set to S-Video and make it PAL, then browse down to UK instead of univeral PAL setting ?.
Yeah I've tried all the settings including the same settings which I used with my older set of drivers (which was like you said UK I/PAL), tried 2 different connections too (S Video and Composite) but nothing worked :(
Did a search on google and there are a fair few amount of people experiencing the problem too.
Oh well, no biggie as I'm not currently playing any games which would benefit from the driver update anyway...well not yet anyway :P
Can't even install these drivers. Complains that I don't have a 64bit OS. I've got vista ultimate 64 bit so no idea whats going on here. Lots of other people in the nvidia forums with same problem. Tried driver clean but still the same.
From the Vista Release Notes:
NVIDIA Control Panel Pages that are Not Yet Available
Support for the following control panel features is under development and not yet available under Windows Vista:
• Display Category
• Run display optimization wizard
• Move CRT screen position
• Manage custom timings
• Run multiple display wizard
• Video & Television Category
• Adjust television color settings
• Adjust screen size and position
Ditto, apart from I have bought Bioshock and cant play it, I was going to get WIC but I understand you need the latest drivers for that too. I am voting with my wallet and not buying any new games and letting the game manufacturers know.
