what do you use to attach fans to passive coolers ?
4 Feb 2003
telford, shropshire
thinking of putting a fan onto a passive cooler that i have, whats the best/safest way to attach it has there are no clips ?
cheers.
depends on the kind of cooler it is but zip ties usually do for me, or even elastic bands if need be.
i used 4 matches, superglued them to the fan, then superglue the over ends of the matches to the heatsink.
has held on for about 3 years now....
Or good Old Duck Tape !! :D
Thin cable ties that go through the holes for the screws on the fans that then just wrap them round the cool/card?
I use Unicorn tears shed by the light of a blue moon....
But, if I haven't got any of those, then cable ties!
I use Guarden wire because it was there. - be careful if you use this not to bridge any connections. In fact I don't reccomend it and must get myself some cable ties.
Well, we're never talking about that much heat in computer cooling.
So, not enough heat to melt a cable tie, and certainly none of mine have ever melted!
