recommend graphics card upgrade
27 Jan 2007
I've got the following pc:
Athlon64 x2 3800, Asus M2N E, 2x512 5400 corsair pro, ati x1600pro 256mb, seagate sata2 160gb, pioneer dvd rw, thermaltake 430W.
I wanted to upgrade to a better midrange graphics card like the x1950pro, but im not sure whether my PSU would handle that. I know that the 2600xt doesnt need to be connected to the psu and is less power hungry..
Any recommendations....Around 100 quid.
Thanks
Vman
Can my psu handlle that card though??
Has your PSU only got 18amps on the 12v rail?.
If so then it might not be up to it.
My PC (in the sig) runs of this PSU http://www.xoxide.com/purepower.html.
It's only 22amp on the 12volt rail and I should be 26amps for my graphics card. I also overclock without a problem and my hardware limits me and not the PSU.
So as it's Thermaltake and could be based on my PSU, it might be able to power it. Might!.
Should be fine to be honest, I ran an X1900XT 512MB on a 460W PSU with 29A on the 12V rail and it was pefectly fine. The X1950Pro uses considerably less power than its bigger brothers too. :)
Well maybe on the fact of it being the x1950 pro.
How do you explain me running 24/7 in my sig on 22amps on the 12volt rail on my PSU though :confused:.
I've been worried about it for a while but it's been solid. I'm stumped tbh.
Sorry I read it as 28A and not 18A.
Seriously doubt 18a will be enough if that is all your psu has. Have you checked your manual or the label on the psu?
ATI recommend 30a for the x1950pro but they are always conservative but never that much
I had a quick look for vman's PSU and came up with a Thermaltake with 18Amps http://www.thermaltake.com/product/Power/TR2power/w006970/w006970.asp. It could be different though :confused:.
My PSU has 22Amps on the 12v rail from that link I posted but I'm going to have a look to see if mine is any different as I think 22Amps is way too low for my rig to be running and for little over a year now at these speeds.
Aye 22A is a bit low for your rig, maybe your PSU is just extremely efficient. :)
checking the PSU's manual i read the following
+12V1 +12V2
15A 18A
I'm not sure what that means...Does it have 2 12v rails.?
+12V1 +12V2
15A 18A
Yup, two 12V rails with 33A total, which means it's powerful enough to run pretty much any graphics card out including 8800s etc. assuming it's not woefuly inefficient (unlikely being a Thermaltake.) :)
Wow. It is the right specs:eek:. I've just taken the side of my case and read 40Amps on the +5v / 30Amps on the +3.3v / 22Amps on the +12v. http://www.xoxide.com/purepower.html
I've had this CPU to 2.95Ghz before but with no stress testing as 2.8Ghz is just manageable heat wise dual stressed. The motherboard limits me with 300FSB so I'm fairly impressed with this PSU. I think it could take more if my motherboard didn't limit me. I've not had a problem with it for nearly 2 years now. Only the case and PSU remain from my original build.
That's what I was hoping to find on the side of my PSU :D.
That is perfect as the others have pointed out too.
