Maybe I'll be wasting my money unless I can overclock it more and get even more performance out of it.
It's not just about performance. I would buy one if just to keep the card silent at load.
Not really mate the card will become silentbe much cooler also so helps its longevity!
You could clock it if you wanted to but by no means a pre-requisit!
It costs 35 notes tho, I'll have to sell Bioshock for it, oh well dont play it anymore.
Btw do you really need a fan on it ? Would it be fine cooling the card without one ?
Monitoring with ATI tool, i get about 55c at idle and 70c under load for the VDDC.
Thanks. Looks like the hr-03 is cooling the core but the vddc is running a lot hotter (115c on load).
I wonder is there anything i've done wrong in the installation or is it just that the stock cooler was cooling the vddc and the hr-03 is'nt?
Stick a fan in front of it or something.
wouldnt it be blowing the warm air from the actual heatsink back onto the card tho if its blowing onto it?Should be blowing up (over the fins) then it should also cool the ram sinks.
