hi i need help as i've got 2 versions of XP installed on my HDD's now the one that it boots to isn't the one i need it to boot to. how do i make the PC boot to the other version
basically i had xp installed and then i installed a version of linux on another partition, didn't like it so i wiped the partition it was on and so XP wouldn't boot then.
so i've put a fresh install of xp on that partition so i can use the pc.
so i need to get back to the old version of xp and delete this version.
thanks
thanks
