the base spec macbook only comes with a combo drive, dvd and cdrw. you can get the superdrives and install it yourself, but that upgrade would invalidate the warranty. upgrading the hd and ram is fine under the apple warranty
HDs to upgrade are just standard 2.5" SATA, for example:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-140-SE&groupid=701&catid=14&subcat=896
Yes, they're 2.5" SATAs .They're Apple OEM as they're slot loading and fit inside the casing.
Can somebody confirm that the HDs are SATA please? I doubted myself.
I know someone's said it before, but whhhhhyyyyyy not just give the discount at the checkout?!
Right thanks for all of the advice everyone.
I have decided i will be going for the 13-inch: White 2.16GHz for £779.03. Just have to sell my current system now.
THEN the Macbook will be mine all mine.
Thanks again everyone.
Good choice, I will guarantee you will fall in love with it![]()
Money in the bank = interest
It would be nice if you got the discount at the checkout though!
