1080p HD (codec) read from DL-DVD?
5 Mar 2007
Macclesfield
Hello,
I’ve got a media centre PC and have downloaded a load of HD media (WMV and .mkv containers), as I’m running out of drive space I’ve been backing up wherever possible, I’ve discovered that 720p films can be read form a DVD drive without any issues. However, 1080p films have ‘jerky’ playback, without too much knowledge I’m assuming either:
There is something wrong with my DVD-drive (unlikely as I have a total of 4 in 2 PC’s)
1080p films require too much info to be read on the fly from a DVD drive (I don’t know the bitrate but as the quality is superb I’m guessing its high – 8GB file size)
If I’m correct and 1080p films can’t be read on the fly, I’d guess my option’s are limited to a HD optical drive of some kind (too dear at present), or an external hard drive, my question is, are the USB external cases quick enough to be streamed through a USB port for a HD codec?
Unfortunately I don’t know the exact bitrates of the films but I’m guessing if you know the answer to the question you’ll know the standard rate for a 1080p ~2hour 8GB film anyway!
Thanks in advance.
You don't provide the spec of your PC, I'm guessing it's not powerful enough for 1080p playback. I had this issue with a single core 3700+ fine after the jump to 4200+ dual core.
Sorry, PC is fine for 1080p (well I say fine, it does still require a lot of the CPU) as I run the 1080p no problem from the hard drives:
Vista 64 bit
C2D @ 2.6
4GB Ram
8800 GTS 64meg
can you run 1080p fine form a DVD?
Cheers
1080p films require too much info to be read on the fly from a DVD drive (I don’t know the bitrate but as the quality is superb I’m guessing its high – 8GB file size).
Yup, 1080 HD films are typically 16megabits upwards, a standard DVD drive has a theoretical limit of 10megabits regardless of read speed.
So USB 2.0 with a speed of 40 MBytes/sec, sould be fine.
Thanks for the info.
Extrernal USB 2.0 case and new drive it is then.
Putting a standard dvd-rom drive in an external caddy wont make it read any quicker.
You quote the throughput of the usb interface not what the drive can actually read at.
There is nothing to stop you playing 1080p material from even a USB2 DVD-ROM.
The 10Mbit bitrate is the maximum for the DVD-Video standard (shared between video and audio), nothing to do with the speed the drive reads at. Even a 4x DVD-ROM reads at about 48Mbits per second. There's more than enough speed in a current DVD-ROM drive to stream a 1080p mvk or wmv from a DVD+/-R DL.
How fast is the DVD-ROM rated for reading DVD+R Dual Layers? For example, a Pioneer 112D will read them at 12x max.
Other than the drive running in PIO mode, i can't think of any reason why a 2.6GHz C2D would break come close to breaking a sweat playing such video.
There might be something in this actually.
I just played a 1080p MKV from my aging 16x Lite on DVD-ROM on my HTPC. While it played fine, the disc was spinning at quite a speed at the start. This was only a single layer disc, as i don't have any 1080p stuff on DVD+R DL at the moment.
What i find hard to understand, is i can stream HD-DVD over a 100Mb ethernet link to PowerDVD 7.3 ultra, and have no framerate issues whatsoever.
sorry i should have made it clear i was refering to a External Hard Drive not an external DVD-ROM
yep I can read 720p on the fly but 1080p is 'jerky'. Someone told me DVD-ROM can only be read at 10mb/sec and 1080p are ~15mb/sec, therefore problem. if this isn't the issue or there is a work around some please let me know before I start buying external hard drives (my 20mb connection is on overtime downloading HD content!)
