Vista basic must be faster ?
  • Thread starter Thread starter T C
  • Start date Start date
T C
T C
13 Nov 2002
'Ull
Been reading reviews all over on vista, and basic is always mentioned as being unusable yet the only difference i can see is the media centre which is crap imho and aero which is just a flash desktop , yet the min spec of basic is 512 mb and min spec of the others is 1gb ram, so surely as a gaming machine basic is the best alternative as it doesnt have background services running that you dont need
who uses aero here ? and is it worth the extra £10 and how much memory can we save not having thses things ?
am i missing something here, as personally ive always wanted an os that just does that, operates the system and doesnt bundle loads of useless crap with it, i only wish it was even more basic and binned ie7 windows mail and the burnng software etc
Aero is turned off when you run a game, so the impact is essentially nothing (tests done with Aero active and inactive proved this).
On a decent PC with 2GB of RAM or more, a decent CPU and graphics card, there's really not much to worry about. I personally keep background services/processes to a reasonable minimum; I'm happy to leave most things like AV software, keyboard software etc running, but I'll close MSN and I don't like those annoying system tray icons many apps install. I've also turned off a select few Windows services that aren't needed, but all in all, there's still a decent amount of stuff in the background and I still get damn good performance.
so if you got basic you could have saved a tenner and not had to turn them off ;)
No...because I wanted Aero (Vista without Aero is bland), and the Media Centre.
Plus I bought the Educational version of Home Premium, so it was cheap anyway.
personally i would pay MS an extra £10 to remove everything but the core os so i could just start the pc and play a game
fair dos but i am talking theoretically just a gaming machine , aero is turned off while playing games and that is all this machine is going to be used for so its not needed ..
i was looking at the edu version as well , how do they go about proving your elligibility when activating it ? i home school my youngest child so must be elligible
It'd be interesting to see a benchmark between Vista Basic and Home Premium, but in all honesty I can't imagine the difference being perceivable in gaming. A decent-spec PC isn't going to be affected by a few idle processes in the background.
As for eligibility of the Educational Version of Vista, I've not had to do anything like that as yet (I am a student though, for what it's worth).
Aero in my eyes is what makes Vista, its just so much nicer to use with the very smooth and sleek desktop.
but not practical i had it on my laptop thought it was cool for a month then turned it off to save seconds opening my mail
Windows Media Center is also very handy to have.
have to agree with that one on my media pc with the xbox, works brilliant but on a single pc there are many apps out there that beat media centre
probably not much difference playing, but the initial booting of all the rubbish and starting of the game i reckon would be slower , i'm only asking as im rebuilding my gaming pc its a quad 6600 2gb ram and a 8600gts until i can afford a 8800, and was wondering which os to get and whether i would be missing out if i get the basic , probably going to go for 64bit as well
I really don't think you'd notice a performance difference at all. Vista boots quickly, runs quickly, loads apps and games quickly. Maybe if you're on a pitiful Sempron with 512MB of RAM you'd find Basic to be quicker, but on the spec in my sig, I find Home Premium to be plenty quick enough.
Have you actually even used Vista yet or are you just going on Pictures, Videos, the Vista hate crew etc...?
have vista on my laptop on my media pc and on my gaming pc which is getting rebuilt hence the thoughts right now
its just not quick enough for me lol that extra second counts .............. besides that the extra tenner could get me a box of guinnes
You have Home Premium right?
Home Premium is definelty worth the pitty £10 over Basic.
All my applications, games etc load instantly for me, so dont know what your problem with your system is.
I'm using Vista a good while now and IMO its not the add on crud that slows it down. Its bad coding thats causing a lot of the slow downs. Simple tasks sometimes take ages for no good reason. Its slowly improving with every update that gets released. Its much faster now than when I originally installed it. Since basic is pretty much the same as XP and XP is faster seems a no brainer to stick with XP unless you want the tarted up GUI of Vista.
