- 23 Aug 2004
I'm building a new computer, which is the better OS? 64 or 32 (prenium) I have no idea what the difference is!
I'm in the same boat 64bit or 32bit I have got xp pro 64bit on at the moe and its been hard work getting all the drivers, for things like camera's, dig TV tuning card and some other stuff.
I think I will try 32bit vista first see how it goes if its worth upgrading to 64 then I'll just pop the vista disk in and rebuild using the 64bit version.
I can say from someone that had 2gb. Its sufficient. Not great, but it does the job. With games and apps the like.
BUT
Im getting another 2gb tommorow, just to make it run that little bit sweeter
Also I have the 64-bit version, and its great...
Well i can say from someone that has 2GB, my system runs flawlessely, very fast and no slow downs what so ever.
If the hardware is recent and any good, there are 64bit drivers out for it.
I've got 1.5Gb RAM, and it flies on mine. It really can depend on chipsets and driver combinations - I've had it run far better on an Athlon XP 2400+ system than on an Athlon64 3500+ system with more RAM - which makes no sense at all.You sure you running the same vista as i am?![]()
Really? It's far better than XP's.Vista has horribly memory management to be honest, kinda sad.
Go for the 64-bit version, future proofing and all, plus drivers etc are generally fine, unless you make music as i do, you're out in the cold on a lot of things then, at least got my keyboard working now but audio interface, software etc doesn't work.
