Just as a test, download Netstumbler. Install and run it. See if that detects any nearby wireless networks. If it doesn't, then I suggest fully removing all software/drivers assoiated with the card and trying some different drivers.
I had an odd issue ages ago whereby I had to type the whole key in full 128bit, rather than the ascii version of it. Have you selected the option to type the ascii key in?
What encryption is being used? Have you tried turning it all off? Have you enabled mac filtering?
I agree that no networks visble suggest wrong drivers or conflict between XP wireless config program and a manufacturers utility. Some chance also that one or more of the properties of the adapter have been set to something such as radio off.
