If it only crashes one core i'd suppose it's a CPU issue, not sure![]()
Yeah I thought it was weird only one core failing and the other carried on without any issues for another 6 hours.....has anyone had this before?
Try the RAM at 2.2 if it was stable at that. Only up it to 2.3 if its crashing the PC regardless.
If the extra voltage settings above increase stability then the RAM is obviously fine as no speeds or latencies will have been changed, just a little extra voltage through the CPU.
If its still the same with the CPU voltage increase (above) and crashes out, then slacken off the RAM timings (above) and increase to the other voltages I've listed above!
*EDIT*
Just read this back to myself and I'm struggling to understand my own waffle so:
Put simply....up CPU voltage to the setting I listed above.
If its still unstable try the RAM settings (above) at your original CPU voltage... touch NOTHING else)
If its still on the blink..use the settings listed above together.
"Phew"...now I understand! LOL![]()
ya being greedy lo 3.6 on air is impressive lol
Just to let you know....my temps are all well within normal. CPU 34 @ idle & 45 under 100% load.
As measured by? If using older versions of coretemp etc.. u're seeing 15C less than it really is (G0 stepping has 100C Tjunction as opposed to 85C for the older stepping). If going by the mobo utility it's likely wrong. Not sure about the latest speedfan and TAT but the core temps will likely need adjusting +15C since you have a G0 chip. Temps you got there seem a little on the low side for that speed and voltage.
My temps & voltages......
Would all these be using the same incorrect temp? Adding 15 degrees is still ok for what I'm doing isn't it?![]()
Hmm i just got Coretemp working on vista, and it says that the temperature is about 63 degrees on each core, a figure i'm a lot more comfortable with. I suppose i can just go uninstall speedfan then and trust Coretemp, that's the program i'm seeing most quotes from anyway?
Yep, is that under load though? if not then its still way too high for idle.
You got the right ver of coretemp, thats a cool runner, what cooling are you using? The ambient temp must be quite cool too!
Yes that's after about 20 minutes of Stress Prime, thanks a bunch
Have been wondering about this all the time really, couldn't understand how 2 x 63 degrees could equal 78 or so, gonna stick to Coretemp now, thanks a lot![]()
when using air, i don't do much phase/water anymore)
So the saga continues.....
I have been able to increase to 3650Mhz which is looking stable (Only used a blend test for a few hours...will do the usual 12 hours overnight).
The settings I am using are:
VCore 1.4875v
HT 1.6v
NB 1.5v
SB 1.5v
CPU VTT 1.45v
RAM 1.9v
PCI-E 101Mhz
RAM Timings 5-5-5-15 (It will boot up using 4-4-4-12 but does not feel as stable, not run any long tests though)
FSB 1624 (9x mp)
So all seems OK....but as soon as I try to increase it to FSB 1645 (3700Mhz) with the same settings it gets past POST, Loads XP, allows me to login....but then freezes after 10-15 seconds
I have tried the following (Resetting to working settings each time unless specified):
1) Same working settings, changed RAM timings to 5-5-5-18 - No boot
2) Same working settings, increased RAM to 1.95v - Loads, freezes after 10-15s (Same as without RAM volt increase)
3) Same working settings, increased VCore to 1.5v - Freezes while loading XP (No login screen)
4) Same working settings, increased VCore to 1.5v, Increased RAM to 2v - Freeze while typing password to login to XP
So tried a few different things....I have noticed that if I use working settings but increase RAM voltage to over 2.1v it does not go past POST...weird as the RAM is certified to 2.2v. It will even freeze the BIOS upon reboot
OK so there's a rundown so far.....has anyone got any opinions/help on what I can do next?
Do you think it could be a RAM issue? If so would it be worth buying a GeiL 2GB kit which is on offer here at OC?
Any input/help would be appreciated![]()
