can you run crysis, heres the link
just done the test and it says c2d e2140 @2ghz and my 8800gts arnt recomendad lol.
wounder how well this game will run. it says that my vid card failed on ram and i only use a 19" monitor so hopefully this shouldnt be a problem but i guess i need a new cpu.
***EDIT***
just done a check on medal of honor airborne and it says that i have failed on my cpu but video ram is fine so if my video ram isnt an issue for crysis and it runs like airborne did id be well pleased :D
It lies, stupid app, I've played the beta fine; Is the dam thing saying the beta is less optimized than the full version :confused: ?
u have a gs,,, the minimum is gt... that why it fail
My gs has a higher 3dmark05 score as the stock GT, but the that's not the point, they say a 6800GT is needed, wich isn't true as I've played it on my card and my mate could run it on his 6600GT (the beta), @800x600 fair enough, but still, minimum requirements should be really minimum requirements.
Also since when is a 9800 equal to a 6800GT ?
My gs has a higher 3dmark05 score as the GT, but the that's not the point, they say a 6800GT is needed, wich isn't true as I've played it on my card and my mate could run it on his 6600GT (the beta).
u missing the point... the company recommends the minimum as 6800GT but it doesn't mean u can't run it on a 6800GS or a 6600GT.....
http://www.crysis-online.com/Information/System Requirements/
Minimum Requirements
CPU:Intel Pentium 4 2.8 GHz (3.2 GHz for Vista), Intel Core 2.0 GHz (2.2 GHz for Vista), AMD Athlon 2800+ (3200+ for Vista) or better
RAM: 1GB (1.5GB on Windows Vista)
Video Card:NVIDIA GeForce 6800 GT, ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or better
VRAM:256MB of Graphics Memory
Storage:12GB
Sound Card:DirectX 9.0c Compatible
ODD:DVD-ROM
OS:Microsoft Windows XP or Vista
DirectX:DX9.0c or DX10
