Vista Memory Useage
Caporegime
18 Oct 2002
London
Recently upgraded from 2Gb to 4Gb. When i was using 2gb (Vista 32bit) only about 800Mb was been used when idle. Now though, 1.8Gb is been used by Vista (64bit). Does that not seem a bit excessive?
Talk about timing, only just noticed that thread just after posting mine. Ok just checking - 1.8Gb seemed a lot to me as even on 4gb it was only just over 1Gb a few days ago.
If it is superfetch, then it's not a problem as when you run a memory intensive program the chached programs are simply overwritten.
Burnsy
Why do you want your ram sitting there doing nothing? :) If a program needs the memory in use it will be released.
Isnt solid state storage limited to a certain number of writes before it fails? So if you have windows writing stuff to ram that may not even be needed and may just be overwriten, its wasting some of the writes, meaning it would wear out the ram sooner. Thats why it is sometimes good to have ram sitting there doing nothing.
Ram isn't solid state
according to wikipedia it is, since ram doesnt contain any moving parts, unlike a hdd for example, which isnt solid state. Its just a volatile type of solid state memory, unlike flash memory which is non-volatile.
even the dictionary agrees with me:
sol·id-state [sol-id-steyt] Pronunciation Key
–adjective Electronics.
designating or pertaining to electronic devices, as transistors or crystals, that can control current without the use of moving parts, heated filaments, or vacuum gaps.
ram doesnt use moving parts, heated filaments or vacuum gaps. As far as im (and the dictionary/wikipedia) is concerned, wether the device retains or looses its data after being powered off doesnt change wether its solid state or not.
Nope perfectly normal... although I recommend using Process Explorer (not Windows Task Manager) as PE gives a more accurate representation of *actual* memory usage.
4GB on Vista x64... same here :) It absolutely flies doesn't it? :D;)
My XP box uses 400Mb doing nothing while my Vista box uses 800Mb to do nothing :(.
Although as it Vista it's obviously doing nothing much faster :D
