XBox 360 Clock Reseting
27 Jul 2003
Hi All,
Is this normal that the system clock resets to 22/11/05 after the power is turned off, couldn't understand where my orange box saves were going until I realised it bases save progress on the system clock.
System was not connected to the internet, as I don't use live.
I'll fix it by having it now always connected to my router, but is this normal?
After a quick Google, apparently it is quite normal. If you turn the power off, it resets the clock. It doesn't have a battery in it like a PC. Which I suppose you can understand if MS are trying to keep consoles as cheap as possible. 10 million £1 batteries is another £10 million cost to them.
Hi All,
I switch my stuff off at the wall everynight including the 360. I noticed this with my original Xbox at first which was a total pain because it didn't update over the internet but I haven't had a problem with my 360 as it seems to set the time from the internet every time I switch it on :confused:
I have however stopped switching it off recently because my Logitech Z5500's loose their settings overnight :(
Doesn't it run off a capacitor for a short period of time?
I moved house in January and my Xbox360 was unplugged for a few days. I know it didn't reset then either though?
I know it was always one of the things that drove me mad about the original Xbox.
If it does only run for a short period of time it must be ~4 days or so?
Was it connected to the net when you booted it back up?
