I've lost my stuff help!
29 Dec 2005
Northants
Just accidently deleted like couple of gigs worth of important stuff by accident is there anyway I can recover it I used the Shift + Del to delete one folder but it started deleting half of my documents folder I stopped it half way through but am missing loads of important stuff is it lost forever or?
Go to the recycle bin on the desktop and reinstate the deleted files.
If you don't know which they are then just reinstate them all!
gt
Thanks a lot :D I got my stuff back thank god, I used the program Recover My Files and worked like a charm. Deleted bout 6gb worth of stuff with in a few seconds
Again thanks a lot people! :D - JoeBoi
Recover my files is good if you simply Deleted them but I cant remember if it actually get the files back as they were like "Example.mp3" or its just DAT's.
If you want them back inc correct file names and DIR location use File Scavenger but its a bit stonger and aimed at recovering total wipe jobs like a HDD claiming its RAW after a Mobo fries etc (happened to me).
http://quetek.com/prod02.htm
