Keyboard recommendations
In that case you'll be fine, they will be much better quality than most speakers attatched to any keyboard you will buy for £150.
I'd like to stress again that I would seriously recommend a second hand Yamaha CS1x synth, it doesn't just have synth noises it has a fullset of normal instrument and several drum kits. Oh and proper midi ports and knobs to twiddle.
One went for £75 a few days ago and one for £69 a few days before that.
That my friend is an absolute steal and will blow most keyboards out of the water, fantastic piano sounds some nice analogue style aphex twinish pads and a great Floydy preset called wish"U"here :)
Dammit, you may just end up bidding against me :D
Gonna ask in this thread... does anyone know what an alesis QS7 might be worth these days? It's a 76 key synth with some quite nice sounds on it...good working order, but must be about 10 years old or so now :(
Not likely as I don't use ebay and would much prefer new equipment.
Thanks mate, go tit working.
This software is the least user friendly thing I've ever come across, anyone have any recommendations for alternatives?
Ok, then a few questions to help me on my way:
I've just found out how to assign the drum pads as a separate group of instruments, any idea how I assign individual keys to separate drums?
also I hardly have any choice of "instruments", any idea where I can get more from (such as honky tonk piano, standard piano etc)?
It took me 2 hours just to get the standard keyboard working!
Check on the m-Audio website for updated drivers.
In the past my Oxygen8v2 didn't get picked up properly (picked up as the old version). The new version of the drivers recently on there sorted that out for Reason.
