Make sure you know how to reset the Bios and just stick it to some stupid fsb.
give bonus points if the pc ends up overclocked
The only thing, it has to be as if it has just happened and no one has had access to the inside of the PC. Unless it has been dropped in transit etc. Changing the BIOS settings is a good one.
If its supposed ot be like its just happened, then just replace fuse in the kettle lead with a blown one. See how long they faff about concentrating in the case for before looking at the obvious, 'cos they prob expect it to be a problem with the innards components, and that won't always be the case.
If its supposed ot be like its just happened, then just replace fuse in the kettle lead with a blown one. See how long they faff about concentrating in the case for before looking at the obvious, 'cos they prob expect it to be a problem with the something in the case. Maybe then you can seperate the lateral thinkers? lol
lol.Mav you make me laugh some times. And cry some other times lol.
Sorry
Hey you twisted my words![]()
How about move the CMOS jumper to the "clear" position. It won't boot then
Alternatively disconnect the power switch.
better than twisting the gonads eh
unless your into that sort of thing![]()
