Corolla T-Sport
18 Oct 2002
Castle Anthrax
Anyone know anything about these? I'm particularly interested in knowing if the gearbox is a C60 (Same one used in 6-spd Celicas)
Cheers. What does "T3" mean in the context of Corolla model names? I'm looking at picking up a gearbox which is described as being from a "T3 T-Sport" and I'm unsure as to whether the seller is getting 2 different models mixed up as pretty much all I can find about T3's is that they are either 1.4/1.6 or 1.8 Versos with a 5spd box.
T3 is a different model to the T-sport, as far as i know only the T-sport used that gearbox, either me or the seller is getting mixed up, I'd seek some clarification from them on its origins!
It's a while now since i had the corolla so I havent really kept up on whats changed, but at some point i think the 6 speed found itself attached to some engines other than the 2zz-ge, worth investigating.
Interesting thing to do there, are you planning on doing it yourself? what sort of benefits do you hope for?
which lsd fits in those, will diffs compatible with the c-52 fit in a c-60?
just interested am a bit of a toyota fanboy :p
What's started this is that my gearbox needs to come out anyway so i'm looking at options as to what I can put in there.
Standard mk1 gearboxes are all at least 18 years old and generally suffer from dodgy syncros on lower gears which were never really up to the job in the first place. It's not uncommon for owners to swap the gearbox out for a 'good' one only to find themselves doing the swap again a couple of years down the line so I'm looking for a newer gearbox which has had these weaknesses ironed out.
Seems that most recent Toyotas with 1ZZ or 2ZZ engines have a box which is derived from the Cx series and so can be used once you've swapped the bellhousing and maybe swapped the gear selector mechanism from one side to the other. Plan is to do the work myself although I'll be taking a different approach to the link above which won't involve dismantling the whole box just to get the bellhousing off. Apparently you can just undo the external bolts at the bellhousing end and then open the box up enough to get a spanner to a couple of internal bolts which will then allow the bellhousing to be removed. Much easier although I'll still have to faff with the diff preload. Would make sense to stick an LSD in at the same time but they're a bit pricey so we'll have to see about that.
I'm trying to get a 6spd at the moment but will settle for a 5 if needs be just a matter of waiting for the right box to come along at the right price. Need to get rid of another car before I can start on it anyway.
Unfortunatley the corolla box turned out to be a 5spd from a T3 in the end. Shame as I've now learned that the gear selector is on the correct side on the Corolla boxes whereas a celica box (my most likely source of a 6spd) will need this swapping.
Sound good:cool:
I've not tried the 5 speed, but the 6 speed is a nice box, 1st and 2nd are not setup for a quick 0-60, but rather 2nd to 5th are setup as a tightly spaced close ratio box, certainly with the 2zz-ge anyway.
6th gear go's onto to something silly like 160mph+ ;)
my sister compares our corolla to a metal plate, perfectly functional and will never break no matter what you do to it, its is however, pretty unrefined and dull.
I have a habit of telling people what they already know but just incase- its only the 04 onwards T-Sports that have the 6 speed box, prior to that they were 5 speed.
