Permabanned
- 19 Jun 2007
- InURmama
@ JohnnyG, Ok or smaller still ? thats 1024x768
One core is loaded more than the others, overall its not overly cpu dependent as far as I can see. Looks like DX9 uses more cpu power than DX10 (as you'd expect). ([email protected])1 core doing most of the work and I would expect it to take it to 100%, its said to be more so like above on Quads, I aint checked on my Dual yet.
If the game really is more CPU dependant as Crytek's CEO Cevat Yeril, then thats why FPS are bad, they need get it to rape all 2 or 4 Cores to near/100% like games normally do for Single/Dual cores.
i have a 8800 gtx, fresh windows install today and new nvidia drivers and crysis on very high on everything and no drag at all
can't see what people are complaining about.
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 125.12s, Average FPS: 15.98
Min FPS: 12.37 at frame 1956, Max FPS: 19.49 at frame 874
Average Tri/Sec: -11176223, Tri/Frame: -699192
Recorded/Played Tris ratio: -1.31
!TimeDemo Run 1 Finished.
Play Time: 122.17s, Average FPS: 16.37
Min FPS: 12.37 at frame 1956, Max FPS: 19.97 at frame 871
Average Tri/Sec: -11321110, Tri/Frame: -691555
Recorded/Played Tris ratio: -1.33
!TimeDemo Run 2 Finished.
Play Time: 122.14s, Average FPS: 16.37
Average Tri/Sec: -11309894, Tri/Frame: -690708
!TimeDemo Run 3 Finished.
Play Time: 122.09s, Average FPS: 16.38
Average Tri/Sec: -11315314, Tri/Frame: -690725
TimeDemo Play Ended, (4 Runs Performed)
Play Time: 86.16s, Average FPS: 23.21
Min FPS: 18.70 at frame 146, Max FPS: 27.94 at frame 1754
Average Tri/Sec: 21197770, Tri/Frame: 913198
Recorded/Played Tris ratio: 1.00
Play Time: 83.15s, Average FPS: 24.05
Average Tri/Sec: 22361324, Tri/Frame: 929626
Recorded/Played Tris ratio: 0.99
Play Time: 83.07s, Average FPS: 24.08
Min FPS: 18.70 at frame 146, Max FPS: 28.47 at frame 870
Average Tri/Sec: 22401618, Tri/Frame: 930489
Play Time: 82.88s, Average FPS: 24.13
Average Tri/Sec: 22451002, Tri/Frame: 930402
I think i might go 8800 GT SLI
I can't i'm on x38![]()
What makes you think that?Surely you can on X38![]()
Though the hardware interconnects are all there for it to work in theory it doesn't due to nvidia being selfish with their sli licence. AFAIK you need another discrete chip on the board, from nvidia. This allows sli to function properly. It's why you can get sli on intel laptops now.![]()
Ohhh I see they are for Crossfire, I would have thought by now there would be mobo's to support SLi and Crossfire on the same board? Apparently its possible with some hacked drivers or something but god performance is not gauranteed?
