- 2 Dec 2004
- Parallel Dimension
Its not a problem with Vista as I had 4GB running straight out the box on Vista64... without any updates installed.
vista 64-bit supports upto 128GB ram out of the box, if its not showing all the memory then its something to do with the motherboard bios.
Well we tried the patch, but it said it wasn't applicable to his system.. Might have already been install.
I might just get him to do an install with 2GB and then stick the other 2GB in later.. Worth a try anyway.
Cheers for the help!
Definitely sound like motherboard bios problem... If the option memory remap isnt there, then im sorry to say it mate, but your MB cant support 4gb...
The board/bios detects 4096mb.If I go into the BIOS, the board picks up 4096MB in the sysem info part so I assume its all there..
There's an option called "memory remap" in the BIOS - this enables or disables support for +4GB ram on a 64bit OS - might be worth a check!
I don't think you need to worry with memory remapping since your bios is already detecting 4gb. Just curious, what chipset is the MOBO built on?
That's great on a 965 chipset with that option in the bios. However, this user has already posted that he does not have that option so it's not a viable suggestion in this thread. We also don't know what chipset he has.When I install the 4gbs my mobo show the 4gigs... but windows only 2gigs with memory remapping off... memory remaping on solve all things...
It's funny how many times the posts here in this specific thread contradict facts already given. The OP has edited to post all the facts and the suggestions are still OT.
