Need a laptop - Then check out this bargain!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We have an amazing deal on what is quite a high specification laptop which is exclusive to OcUK from Samsung.
Samsung NP-R20F004/SUK R20 Intel Core 2 Duo T5300 Laptop - Vista Home Premium
The Samsung R20 laptop is ideal for home and business users. It comes complete with 1GB RAM and 120GB Hard Drive which is more than adequate storage space for music, documents and photographs. Fully loaded with the new Microsoft Windows Vista Home Premium, the Samsung R20 laptop has a fast Intel Core 2 Duo 1.73Ghz Processor and a DVD-RW for all your optical needs. All this is displayed on a superb 14.1" TFT Screen.
Our best deal yet and we only have 100pcs available, an excellent Christmas gift at a fantastic price, be quick as this is a one time only offer!
- Intel® Core 2 Duo Processor T5300 (1.73GHz) 2MB L2 Cache
- 1GB PC2-5300(667MHz) DDR2 SODIMM
- 14.1" WXGA (Glare / Non-Glare) Display
- 1280 x 800 x 262,144 color ( 18 bit ) Resolution
- ATI® Radeon Xpress 1250 Graphics
- High Definition Audio
- 120Gb 5400 RPM SATA HArd Drive
- 8x DVD RW Combo Drive
- 6 in 1 card slot
- 802.11g Wireless LAN
- Dimension 270 x 52.5 x 22.5mm
- Weight 2.3kg
- Vista Home Premium Operating System
- Manufacturer Warranty - 1 year warranty
Previously sold for £459.99+VAT (£540.49 Inc. VAT)
Price: £425.49+VAT (£499.95 Inc. VAT) (A saving of £40.54 Inc. VAT)
BUY NOW!!
shame the screen is so small I was looking go for a cheap laptop aswell :(
HI there
What is an ideal screen size for a laptop too? If you go too big it starts defeating the object of been a light and portable device. 14/15" does seem the most popular when it comes to sales volume as 17" models tend to be quite a bit larger and heavier making them not as easy to transport.
That's actually not a bad price. I have no idea about the current range of mobile processors. Where does this sit power-wise?
Also 1gb ram is a bit iffy- I'd stick XP SP2 on it :p
Hi there
I believe its quite powerful, certainly plenty for a laptop anyway and I may be wrong but I think its a core 2 DUO if I go by what the name suggest which would basically mean it has plenty of CPU grunt.
1GB of RAM is fine for Vista, we've tried 512MB and that was fine with Aero interface disabled. Fair enough XP would be quicker but we now sell SODIMM and upgrading to 2GB is very cheap at the moment and easy enough to do. Just see the OcUK SODIMM section. :)
NEVERMIND, was a core duo rather than core 2.
HI there
You will be looking at a slightly different spec. There are several different R20 models, what I know if that for this particular model with this specification we are the cheapest.
If you have found an identical specification that is match for match and in stock the same as mine please email the link to me at [email protected] because then we shall buy them from there too because the 20 or so competitors I know off are all £30-£70 more than OcUK.
15.4" is what I would class as just right 14.1 is just a tad to small for me.
never mind still a bargain though. mind spam up if you get cheapo 15.4 or 17s
HI there
It had a T2350 rather than the T5300, meaning it is a significantly different laptop with different architecture. Sorry bout that.
