Crysis SP Demo GPU Benchmark Thread
Hmm, my poor x1950xt takes a hammering with all on high and I had to use 1440x900 as I've got a 19" WS monitor, so if anything the scores would be marginally lower still.
Min - 6 fps
Average - 13.5 fps
Max - 21 fps
With the following system: e6300@2ghz, x1950xt 256mb @ stock and 2gb ram.
You can use 1280x1024, 19" widescreen monitors can work at that res just it looks like crap, use it for the purpose of this benchy tho.
At all high 1280x1024 I'd say my average is about 42, min about 23 and max about 49, this is what I seen but unfortunatly have no proof of it since it crashed half way through :(.
What clocks are you on with it crashing in crysis?
I got some better results on this run... same settings as before.
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 56.42s, Average FPS: 35.45
Min FPS: 17.70 at frame 146, Max FPS: 50.33 at frame 1009
Average Tri/Sec: -37988252, Tri/Frame: -1071654
Recorded/Played Tris ratio: -0.86
!TimeDemo Run 1 Finished.
Play Time: 47.53s, Average FPS: 42.08
Min FPS: 17.70 at frame 146, Max FPS: 50.71 at frame 997
Average Tri/Sec: -44668464, Tri/Frame: -1061446
!TimeDemo Run 2 Finished.
Play Time: 47.87s, Average FPS: 41.78
Average Tri/Sec: -44291248, Tri/Frame: -1060098
!TimeDemo Run 3 Finished.
Play Time: 47.60s, Average FPS: 42.02
Average Tri/Sec: -44617688, Tri/Frame: -1061889
TimeDemo Play Ended, (4 Runs Performed)
With these settings.
1680*1050 with 2x AA, SunShafts enabled with the config file. It's how I play the demo.
I'll post it with all High settings later.
1280x1024 - ALL SETTINGS ON HIGH
Play Time: 65.94s, Average FPS: 30.33
Min FPS: 20.70 at frame 1955, Max FPS: 35.89 at frame 385
Average Tri/Sec: 30654354, Tri/Frame: 1010682
Recorded/Played Tris ratio: 0.91
Play Time: 63.50s, Average FPS: 31.49
Min FPS: 19.08 at frame 1941, Max FPS: 36.04 at frame 1773
Average Tri/Sec: 32169878, Tri/Frame: 1021472
Recorded/Played Tris ratio: 0.90
Play Time: 63.46s, Average FPS: 31.52
Min FPS: 18.45 at frame 1950, Max FPS: 36.04 at frame 1773
Average Tri/Sec: 32226946, Tri/Frame: 1022526
Play Time: 63.73s, Average FPS: 31.38
Min FPS: 18.45 at frame 1950, Max FPS: 36.53 at frame 337
Average Tri/Sec: 32051646, Tri/Frame: 1021328
1152x864, all on High, no AA
E4300 @ 2.8GHz
2Gb ram PC6400
8800GTS 320mb oc'ed to some level
XP 32bit
Average = 39.82fps
Min = 17.21fps
Max = 49.94fps
1680X1050
High Settings
700/1700/1000
e6600 @ 3.6ghz (400x9)
169.04 gave me about a 5fps increase over the 169.02 driver.
I've placed a 120mm fan perpendicular to my 8800GT, with stock fan at 60% to 80% dynamic and load temps never reach over 70C on the GPU.
im going to reserve this spot for sli results tomorow.
but as like someone else im going to have to use the very high settings as i lost the cvargroups folder. should be interesting to see if sli makes a difference.
It would help of everyone did the settings the OP requests....
1280X1024 ALL HIGH. So we can get some fair performance comparisons.
Just goes to show how bad Vista is with Crysis those FPS are awfull compared to XP.
