- 10 Apr 2004
http://www.thunder-keep.co.uk/site/macbookproeve.jpg
Reasonable performance.
Need some AA and AF tho...
kk... I hate you.
Who do I have to pod to get me that client?
Ive got to assume your in the closed Beta, in which case... Arhhhh... you just broke the NDA, im telling on you. Unless ofcourse the Open Beta is now available, but, I cannot see any mention of it on the Eve Forums.
There is a news article, you can download the client nowand connect to Multiplicity
It's a .dmg if you look at the top news item at login, then click readmore, about half way down you'll see a link to the .dmg file
Got it running at the moment, probably looking at about a 20% reduction in FPS on my macbook pro over running eve in bootcamp.
I was getting about 15 - 25fps depending, in station 30fps + outside station no one else around 25fps fluctuating, then warping to a belt, 15 - 20fps.
Direct3D HAL (hardware acceleration layer) uses your super-duper 3D video card hardware to speed up shaded mode and realtime rendering on PCs. It is limited by the card memory and the quality of the manufacturer's drivers.
