Tytn2 has the far superior GPS module - I wouldnt even list the GPS as a feature of the N95 as its pretty useless (slow to lock on/loses signal very easily)...N95 8Gb , depends what you like in a handset really, the tytn is too bulky for me and I dont like Windows Mobile (too slow for my liking). Obviously the N95 has better camera and good video functions, GPS and a big memory but the tytn has touchscreen ie has better pda functions - if you want a smartphone go for the N95 8Gb, if you want a pda phone go for the tytn.
theres quite big difference with the original N95 - the build uality is far better - have a look at this vid:
Thats why I am a bit sceptical about the Tytn II.
Thanks for the input. The N95 looks more normal. I currently have a 8700g and am sick of holding a "calculator" when making callsThats why I am a bit sceptical about the Tytn II.
You are supposed to use bluetooth to make calls with pda phones.
Guru - youd better review it when you get it. Ive never had a WM* phone without a QWERTY keyboard so Id like to see how you find it...
Just seems to be a compromise too far for me as I tend to use email/text more now just because its so natural...
ps3ud0![]()
Bluetooth headsets outside of a car makes you look like a plonker in my opinion.
Loads of devices use them, games consoles included.Tytn2 has the far superior GPS module - I wouldnt even list the GPS as a feature of the N95 as its pretty useless (slow to lock on/loses signal very easily)...
@OP - Since you are considering the Tytn2 you must be after something that has some PDA function and if thats the case then its a better choice than the N95 - the proper keyboard makes a lot of difference...
Media usage - N95
PDA usage - Tytn2
ps3ud0![]()
- N95 - media and better as a 'phone'
