- 5 Oct 2005
- Mansfield, Notts, UK
Hi Guys,
Check my sig, got a £D Mark score of 11285.
Is that amy good?
Is that amy good?
Looks good to me, i get 9100 odd all stock.![]()
Is this something to do with Vista 32bit not seeing all 4GB so it's not maximising the efficiency or something?
what settings do you guys use for 3dmark 06? have just run the demo version with default settings and got nowjhere near your scores
I use default, make sure NVCP is at default aswell, try setting texture filtering (I think) to "High Performance"
NVCB? That sounds like something to do with nVidia? I'm using a Radeon x1950 pro (which I should have mentioned I guess!?)
