Just found this log file in the crysis dir
BackupNameAttachment=" Build(1) Date(11 Nov 2007) Time(12 53 17)" -- used by backup system
Log Started at Sunday, November 11, 2007 12:53:17
Running 32 bit version
Executable: D:\Program Files\Electronic Arts\Crytek\Crysis SP Demo\Bin32\Crysis.exe
FileVersion: 1.0.0.1
ProductVersion: 1.0.0.1
Using STLport C++ Standard Library implementation
--- CPU detection ---
Total number of logical processors: 2
Number of available logical processors: 2
Processor 0:
CPU: AMD AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
Family: 15, Model: 3, Stepping: 2
FPU: On-Chip
CPU Speed (estimated): 2264.432345 MHz
MMX: not present
SSE: present
3DNow!: present
Serial number not present or disabled
Processor 1:
FPU: On-Chip
CPU Speed (estimated): 2264.431590 MHz
MMX: not present
SSE: present
3DNow!: present
Total number of system cores: 2
Number of cores available to process: 2
Windows XP 32 bit SP 2 (build 5.1.2600)
System language: English
Windows Directory: "C:\WINDOWS"
Prerequisites...
* Installation of KB940105 hotfix required: no! (either not needed or already installed)
Local time is 12:53:17 11/11/07, system running for 139 minutes
2048MB physical memory installed, 1456MB available, 2047MB virtual memory installed, 28 percent of memory in use
PageFile usage: 26MB, Working Set: 4MB, Peak PageFile usage: 26MB,
Current display mode is 1680x1050x32, VGA
IBM enhanced (101/102-key) keyboard and 5+ button mouse installed
Stream Engine Initialization
Network initialization
[net] using iocp socket io management
Physics initialization
MovieSystem initialization
Renderer initialization
Console initialization
Time initialization
Input initialization
Sound initialization
Sound - initializing AudioDevice now!
Sound - starting to initialize DirectSound output!
Sound - 1 drivers found:
Sound - available drivers: 0 SB Audigy 2 Audio [9800] !
Sound - initializing FMOD-EX now!
Sound - initialized FMOD-EX
Sound - available record drivers: 0 SB Audigy 2 Audio [9800] !
Sound - using FMOD version: 00040723 and internal 00040723!
Sound - initializing SoundSystem now!
Font initialization
AI initialization
Initializing Animation System
Initializing 3D Engine
Script System Initialization
Entity system initialization
Initializing AI System
[PlayerProfiles] Login of user 'Alan' successful.
[PlayerProfiles] Found 1 profiles.
Profile 0 : 'default'
[GameProfiles]: Successfully activated profile 'default' for user 'Alan'
$3r_FSAA = $60 $5[DUMPTODISK, REQUIRE_APP_RESTART]$4
$3r_FSAA_samples = $60 $5[DUMPTODISK, REQUIRE_APP_RESTART]$4
$3r_FSAA_quality = $60 $5[DUMPTODISK, REQUIRE_APP_RESTART]$4
[net 12:53:17.875] network hostname: a-05613af940a14
[net 12:53:17.875] ip:192.168.1.2
[Error] <Scaleform> Error: CallFunction - 'setSlider' is not a function [Libs/UI/Menus_StartMenu.gfx]
[Error] <Scaleform> Error: Invoked method is not a function [Libs/UI/Menus_StartMenu.gfx]
[Error] <Scaleform> Error: CallMethod - can't find method setSlider [Libs/UI/Menus_StartMenu.gfx]
$3r_FSAA = $61 $5[DUMPTODISK, REQUIRE_APP_RESTART]$4
$3r_FSAA_samples = $66 $5[DUMPTODISK, REQUIRE_APP_RESTART]$4
[Warning] Unknown command: fsaa_mode
$3sys_spec_Full = $64 $5[]$4 RealState=Custom
[net 12:56:48.375] connection requested to: <local>:64087
[net 12:56:48.390] resolved as: <local>:64087
[Error] Error: CTexMan::ImagePreprocessing: Scaling of 'textures/cubemaps/camera_wetroad.dds' compressed texture is dangerous (only single mip) [File=textures/cubemaps/camera_wetroad.dds]
*LOADING: Level island loading time: 31.83 seconds
[Error] <Scaleform> Error: CallFunction - 'setSlider' is not a function [Libs/UI/Menus_IngameMenu.gfx]
[Error] <Scaleform> Error: Invoked method is not a function [Libs/UI/Menus_IngameMenu.gfx]
[Error] <Scaleform> Error: CallMethod - can't find method setSlider [Libs/UI/Menus_IngameMenu.gfx]
$3r_FSAA_samples = $64 $5[DUMPTODISK, REQUIRE_APP_RESTART]$4
$3r_Width = $61440 $5[DUMPTODISK]$4
$3r_Height = $6900 $5[DUMPTODISK]$4
[Error] <Scaleform> ActionScript Memory leaks in movie 'Libs/UI/HUD_PDA_Map.gfx', including 2 string nodes [Libs/UI/HUD_PDA_Map.gfx]
[Error] <Scaleform> Leaked string content: '_level0.Root.PDAArea.Map_M.MapArea.Map.Map_G.MapBase', 'MapBase' [Libs/UI/HUD_PDA_Map.gfx]
[net 13:01:04.562] Disconnect <local>:64087; profid=0; cause=17; msg='User left the game'
[net 13:01:04.578] Disconnect <local>:16; profid=0; cause=11; msg='Nub destroyed'
CGameClientChannel::Release
[Error] <Scaleform> Error: CallMethod - 'gotoAndPlay' on invalid object. [Libs/UI/Menus_StartMenu.gfx]
System:Quit
