Anyone had rebooting probs with dual core cpu in xp
17 Dec 2004
I really dont want to change to vista to solve my prob, Ive done all the dual core updates and fixes, but xp just reboots if a torrent downloads too fast or if my g15 keyboard software starts up too fast?
Any ideas guys??
No issues here, using the AMD CPU driver and dual-core optimiser. Could you be a bit more specific as to the symptoms - do heavy-load apps like games run OK? Does it happen at stock speeds?
Reboot is more likely a sign of instability. Try running it at stock speeds, see if that helps. You probably need more volts to the cpu or the ram to cure the instability.
The only program I ever found that really hated dual core was an old version of Network General's Sniffer.
Changing to vista will not fix a 'hardware' problem. Try running memtest for 10 hours, see if your getting any memory errors, and what are your temperatures like etc etc.
Although it would surprise me if its true (not saying your making it up... just amazed that maybe microsoft got something right in vista)... but perhaps vista is better able to 'correct' memory errors on the fly that would cause XP to reset.
I'd still reset your processor to stock speeds to see if that gets it stable, and download and run memtest86 overnight... as long a run as possible. 12hours without errors is generally enough to satisfy me that the ram's stable :P After that prime95 it for another 12 hours or so.
If that doesnt flag any errors at stock speeds (or cause XP to reboot), then you can wind up the overclock again, repeating both the memtest, and prime tests for each time you increase the clock.
XP shouldnt reset without cause on a dualcore system be it intel or amd, unless something is wrong with the system. The number of times people have complained to me about microsofts sloppy codeing of XP... and I've just run memtest for 10 minutes and found errors :P.. XP is actually a very good operating system.
